Blue Dot Taillights
Swegner99
Blue Dot Taillights
Post by Swegner99 »
Where are these available from, I looked through my DC, LMC, and NPD catalogs and didnt see them. Did I overlook them? I think they look great and I want a set, also, anyone know if they come in LED?
Thanks
1972 F250 Custom LWB
1999 F150 Ext Cab
2001 E350 15 Passenger Van
FREAKSHOW
Re: Blue Dot Taillights
Post by FREAKSHOW »
there not the whole light assembly there only the blue dots that you install in to your current tail light lenses. you can get them through summit, speedway and there on page 140 of the new LMC catalog ( 2012 winter edition)
Hawkrod
Post by Hawkrod »
Keep in mind that blue dots are almost universally illegal so if you already have cop issues it can make a bad situation worse as they can use blue dots as a probable cause for a stop. Most cops are cool but every once in a while... Just sayin'. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
91Bear
Post by 91Bear »
You can find some here, about halfway down the page.
http://www.taillightking.com/67-72FordTruck.htm
PhantomoftheBumpside
Post by PhantomoftheBumpside »
Blue Dots are legal in WA on all vehicles more than 40 years old, and any motorcycle regardless of age.
http://apps.leg.wa.gov/RCW/default.aspx?cite=46.37.100
AZ is kind of weird with tail light statutes... You have to have one. It has to be more than 15" from the ground and less than 75" or something like that from the ground. You can also have two when they are wired together with a license plate light as long as they are always on when the head lights are on. They must be red. Apparently AZ may not have thought of Third Brake Lights yet. Anything else seems to be left to the discretion of law enforcement.
-- ROB --
The collective money pit details...
-On The Road-
1990 * 1FTEE14YZLHA83xxx ..- 138 E142 __ E 18 __ 3P
-Projects-
-Spares-
-Recently Departed-
1997 - 4M2DU55P9VUJ46xxx...- 112 4 22 _ _ 8 D4 U 1F
1997 - Dodge Caravan
1987 - Toyota Tercel Wagon FWD
1978 - Winnebago Brave (Dodge D800FC)
1970 - F10YRJ80xxx ..............- 131 3 F100 D _4 G 02
1968 - F25YRC99xxx .............- 131 E F253 B 81 G C8
1968 - F25YRD69xxx .............- 131 C F254 E 81 A 24
I think JCW still carries Blue Dots... but they are probably plastic.
-- ROB --
-On The Road-
-Projects-
-Spares-
-Recently Departed-
Swegner99
Post by Swegner99 »
Hey thanks everyone, Im not too worried about getting hassled by the man for them. Im squeaky clean nowadays as far as the law is concerned. We are right on the cuff of being rural out here in the desert, so the the police dont really mess with anyone too bad for stuff like this. We have the ricers with full underglow and tire chasers that never get messed with so I think im safe.
1999 F150 Ext Cab
michael69
Post by michael69 »
If you buy some, make sure you get the Real glass ones. They cost a little more,but give off a much better purple glow than the plastic ones. I have bought several sets off eBay for my bikes and car projects.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
