Replacing flasher can
91Bear
Post by 91Bear »
OK, my turn signals do not blink. I assume it is the flasher can on the back of the instrument panel but I don't know how to remove it. I was going to swap in a new one once before but it is very solidly attached to the instrument panel. I cannot figure it out. I got frustrated before and just put the instrument panel back in. I have searched the forums but cannot find the secret.
How do you remove it?
72BahamaBlue
Re: Replacing flasher can
Post by 72BahamaBlue »
On your 69, does it have the metal instrument cluster body? Speculation, but it may be stuck from galvanic corrosion. Happens when 2 disimilar metals react to each other, might be corroded in there. Will likely need to take instrument cluster assembly completely out to repair. If it's really stuck in there, leave it and plug a new flasher can into the connector, and find a suitable place to tuck it out of the way under the dash.
I used to leave mine dangling within easy reach...if it acted up, a flick with the fingers would jolt it into working again.
91Bear
Post by 91Bear »
It's almost like it is riveted onto the instrument panel (which is metal). I have tugged and pried and can't figure out how to remove and replace it.
67mann
Post by 67mann »
:hmm: ..my 67 can is mounted to the back of the dash frame by the wiper motor.....no clue if it changed,but I do know thats what makes my blinkers blink..as a matter of fact just hooked it up this am :?
91Bear
Post by 91Bear »
My blinkers come on but don't blink. I assume it's that flasher.
72BahamaBlue
Yup. indicator light stays on? Likely the flasher. Are you able to remove the connector off the flasher?
tylerb43
Post by tylerb43 »
91Bear, my truck is also a '69, (F100) and my flasher is in a "C" clip on the fwd side of the dash support structure. Easily removable. :hmm:
You can see it at the right side of this picture, this is looking straight up. Yours is located differently than this?
fireguywtc
Post by fireguywtc »
Before you pull, I would recommend getting a canister type flasher and plugging it in to make sure that is your problem. In my 67 I had the large box type flasher that is screwed in the the frame behind the dash, I replaced it with a canister similar to the one in the pic and left the other one in place. IIRC the plug was the same. My box flasher was working, but it flashed slow and very loud.
Bill
91Bear
Post by 91Bear »
tylerb43 wrote:91Bear, my truck is also a '69, (F100) and my flasher is in a "C" clip on the fwd side of the dash support structure. Easily removable. :hmm:
[ Image ]
tylerb, I believe that is the other flasher can for the hazard lights. The flasher for the turn signals is behind the instrument panel - for maximum inconvenience!
71PA_Highboy
Post by 71PA_Highboy »
twist to remove.
need pics?
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
91Bear
Post by 91Bear »
Twist to remove? It's screwed in? Pictures would be great.
71PA_Highboy
here you go:
Got Ford?
1 Lincoln Mark VIII
91Bear
Post by 91Bear »
Thanks! Where does one get a flasher with a nipple on it like that?
71PA_Highboy
I got mine off another cluster... I don't think they make them that way anymore, but I could be wrong.
Got Ford?
1 Lincoln Mark VIII
Calvin Gunter
Post by Calvin Gunter »
I recently replaced both flasher cans on "Rusty" and I just loosely zip tied it to the cluster harness.
The other flasher was a box also but I converted it to a round can also.
I got a used flasher clip from Tom at Flashback to attach it to the column support.
1967 Ranger,Short bed,390,C-6,9 inch,4 BBL.,intake,cam,headers,3:55 Posi.,A/C,Power steering,Power Disc Brakes,Automatic trans.DJM dropped I-beams,flipped rear hangers,headlight harness upgrade.ExTang tonneau cover "Old Blue".
http://s508.photobucket.com/albums/s328/BigSxy96/
1967 Base model,352,2bbl.,3 on the tree,short bed,3:25 9 inch "Rusty".
1967 Mustang coupe-show car/garage queen.Small Block,alum. heads,Nitrous,4:11Locker,Areospace brakes "Mystang".
1996 F-250 Powerstroke-Big intake,exhaust,injectors.(Nice Smoke Show) "Big Sexy"
