Adapting a '73 turn signal switch for a '68
sublimer
Post by sublimer »
So the '68 has 8 wires and the '73 9 because of the addition of the emergency flasher button to the steering column.
I imagine 8 of the 9 wires is fairly trivial, just figure out the corresponding wire and hook it in (correct me if I'm wrong). Then for the 9th wire, can I just splice into the wire for the emergency flasher button since I want to keep the switch that's also in the glovebox? :hmm:
This seems to be a pretty easy project, but I've said that before, and then one thing leads to another, so I want to clarify my understanding first! :D
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
basketcase0302
Re: Adapting a '73 turn signal switch for a '68
Post by basketcase0302 »
Do you mean putting a 73 steering column into one of our bumps-then grafting the wiring together? Or installing a 73 TSS into a bump era steering column, (which I don't believe will bolt up to the shift collar)? :hmm:
sublimer
Post by sublimer »
basketcase0302 wrote:Do you mean putting a 73 steering column into one of our bumps-then grafting the wiring together? Or installing a 73 TSS into a bump era steering column, (which I don't believe will bolt up to the shift collar)? :hmm:
I mean taking a 73 steering column and putting it into a 68 then hooking up the 73 TSS switch to the 68's wiring. :D
1968 Ford F-100
Moveable Speakers
Hawkrod
Post by Hawkrod »
Amazingly enough you can put the 73 collar onto an earlier column. I do the reverse when I put a later collar into an early truck and don't want the hazards because it already has one. The only thing you need to do to hook up the hazard light is connect the wire (white w/red or orange stripe) to a flasher cannister and hook the other terminal of the flasher cannister to an unswitched 12V. That is all there is to it. No need to connect it to the existing flashers. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
sublimer
Post by sublimer »
Interesting, didn't know that was possible. Decisions, decisions...I don't like the location of the emergency flashers in the bumps. It's hard to get to as a driver and sometimes you need to switch them on while the car is moving. I had thought about getting a normal toggle switch from Radio Shack, but I think I may want to take advantage of the button.
I'll decide later I guess. But I appreciate the "how-to." Wouldn't it just be easier to hook it up to the existing flash canister though? I believe it's just running one wire. Saves a couple of bucks and reduces the amount of "stuff" going on with the electrical. :hmm:
1968 Ford F-100
Moveable Speakers
Hawkrod
Post by Hawkrod »
You could hook it to the existing but then you would probably want to disconect the existing. If they somehow both got in teh on position it may be "interesting"! I doubt it would hurt anything but if something was odd it would be much harder to diagnose. Due to the simplicity and lack of cost, I would think it would be easier just to keep it seperate. Just grab a flasher from a parts car at the junkyard and use a couple of spade terminals. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
sublimer
Post by sublimer »
Hawkrod wrote:You could hook it to the existing but then you would probably want to disconect the existing. If they somehow both got in teh on position it may be "interesting"! I doubt it would hurt anything but if something was odd it would be much harder to diagnose. Due to the simplicity and lack of cost, I would think it would be easier just to keep it seperate. Just grab a flasher from a parts car at the junkyard and use a couple of spade terminals. Hawkrod
Good point. I imagine that if you hooked up the button and the switch before going into the flasher nothing should happen. I'm nowhere close to an electrical expert, but I couldn't imagine it doubling the amperage or voltage, it would just provide 2 paths to turn the flasher on. I'll do some research, I'm sure someone else has tried something along this path. And I think you can buy new flashers for $5-10, so it wouldn't be expensive either way.
1968 Ford F-100
Moveable Speakers
