Repairing Wiring Harness
davbell22602
Post by davbell22602 »
Someone cut the wires to connector going to the key switch and I need to solder the connector back on the harness. Does anybody know specs for a the wiring harness on a 67 F100 2wd base model 8ft bed? Amps, watts, etc? I know its 12 volts.
72BahamaBlue
Re: Repairing Wiring Harness
Post by 72BahamaBlue »
I think that entire connector is available, new plug and short lenth of wires. Those '67's had faulty switches initially, and replacements were sold with a new connector to splice onto the ignition harness.
LMC catalog, page 129, #31...is that what you need?
davbell22602
72BahamaBlue wrote:I think that entire connector is available, new plug and short lenth of wires. Those '67's had faulty switches initially, and replacements were sold with a new connector to splice onto the ignition harness.
No. I just to solder them back together it was cut. Its like someone couldn't get the connector off of the ignition switch.
basketcase0302
Post by basketcase0302 »
davbell22602 on Wed Jan 11, 2012 7:26 pm
I'm doubtful you'll ever see the wattage rating number for our trucks, (I've never seen one). There were simply too many variations, (too many options). Each slightly individual truck, (ie. CS/cab & chassis/F-100) would all have a different electrical consumption. I believe most our trucks came with a standard 45 amp alternator if that helps. Maybe TF or Hawkrod or someone else knows a little more on this too. :wink:
Do you just need to know a particular wire size at the ignition switch harness to replace?
davbell22602
I just need to know which type or kind of soldering wire to use.
71PA_Highboy
Post by 71PA_Highboy »
Hmmm... there is a lot of argument on this, but I will provide a semi 'mil-spec' answer.
Never solder wires in environments that are subject to vibration, such as a vehicle, as the wicking of the solder up the wire causes a weak spot on the wire that will cause work cracking of the copper due to said vibration.
The caveat to that is: there are special tools that allow that to be done, but in specialized situations.
Personally, I use butt splices. I work some 'Kopr Shield' (sp?) [Made by Thomas and Betts IIRC'] into the wire, then crimp the wire in, then use a QUALITY sealing heat shrink.
If you are going to solder you want an electronic solder, usually 63% tin (or better) rosin core.
YMMV.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
72BahamaBlue
What 71PA_Highboy said.
A good mechanical crimp with quality connectors works very well. Aircraft or marine spec butt splices are my favorite, worth the added cost.
Try these:
http://terminaltown.com/Pages/page98.html
davbell22602
72BahamaBlue wrote:What 71PA_Highboy said.
Try these:
I gotta order some of those see through butt connectors. Thanks
