Testing the idiot lamp...
sublimer
Post by sublimer »
Is there a way to test it? There are obviously things that can break in the system as simple as a broken light bulb.
Is there an easy way to test if it's working or not?
1968 Ford F-100
240cid (3.9L) Inline 6
3-speed on the Floor
2-tone Blacks & White
Custom Homemade Headliner
Moveable Speakers
70_F100
Re: Testing the idiot lamp...
Post by 70_F100 »
Which idiot lamp are you talking about?
sublimer
Post by sublimer »
The left most light bulb next to all the knobs...the dual brake warning lamp.
1968 Ford F-100
Moveable Speakers
70_F100
Post by 70_F100 »
It should come on when you turn the ignition switch to the "start" position. The easiest way to check it would be to first replace the bulb. If that doesn't fix it, there are more troubleshooting steps, but I would start with that.
sublimer
Post by sublimer »
70_F100 wrote:It should come on when you turn the ignition switch to the "start" position. The easiest way to check it would be to first replace the bulb. If that doesn't fix it, there are more troubleshooting steps, but I would start with that.
You are correct, it does come on in the start position...never noticed that before I guess.
1968 Ford F-100
Moveable Speakers
