If you haven't been doing any work on your signal wiring and they worked and then just quite it may be your TSS. Are you assuming the flasher is good due to the emer. flashers working? There are 2 one for blinkers is seperate from flashers.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Check the fuse... If your Back-up lights and windshield washer pump don't work it is the power (fuse), as these are all on the same circuit.
