electrical shutting off
67 ford f100s rule
Post by 67 ford f100s rule »
whil I am driving my bump all the accessories shut off like the guagesd and the radio. Sometimes they stop working and then start working again. What exactly could this be?
Jeff Penland
70 Ford F100 LWB "Nadine" 302/3 speed with overdrive
If you have to ask you wouldn't understand
"I shall hold the line of right as well as that of glory." English translation of the British Penland coat of arms.
elgemcdlf
Re: electrical shutting off
Post by elgemcdlf »
Sounds like it may be a bad or lose body ground. Hard to say on a truck that old. At this point in it's life I would highly recommend rewiring the entire truck. There really isn't that much to it.
Thunderfoot
Post by Thunderfoot »
Ignition switch, these are all controlled by it. :2cents:
1972hiboy
Post by 1972hiboy »
Thunderfoot wrote:Ignition switch, these are all controlled by it. :2cents:
:yt: mine would do this from time to time on a bumpy road. all the accessories would go out but the truck would keep running. Id just reach downa nd jiggle the key a bit side to side in and out and everytime they would come back on.
Rich
Dont eat yellow snow.....
basketcase0302
Post by basketcase0302 »
Id just reach down and jiggle the key a bit side to side in and out and everytime they would come back on.
Good troubleshooting method. Moving the wires around while the engine is running-maybe have someone else watching the gauges. I'd also check out by the solenoid and alternator. :thup:
1972hiboy
Post by 1972hiboy »
Its how I found out my ignition switch was severly worn. I obviously didnt turn the key far enough to turn all the power off just a gentle wiggle and id listen for the radio to come back on. Not very dangerous and worth a try next time it happens. A heavy set of keys can wear out a switch. :2cents:
Rich
bluef250
Post by bluef250 »
Ignition switch is the most likely canidate.
67 ford f100s rule
Thanks for the help guys. I tried it and the accesories did start working again! So I guess it is time for a new ignition switch. I have another electrical question now. My driver rear turn signal is not working. I replaced the bulb and I am still getting nothing. I took a look and I think I found the suspect wire. Any idea where I can get a wiring diagram?
Jeff Penland
BobbyFord
Post by BobbyFord »
67 ford f100s rule wrote:...Any idea where I can get a wiring diagram?
http://www.fordification.com/tech/wirin ... ghts01.jpg
http://www.fordification.com/tech/wirin ... ghts02.jpg
Thunderfoot
If your driver side "Brake light" is working and your "Turn Signal" is not then the problem is your Turn Signal Switch. If both don't work, then yes, start with checking wires and connections for the Yellow wire...
67 ford f100s rule
Thunderfoot wrote:If your driver side "Brake light" is working and your "Turn Signal" is not then the problem is your Turn Signal Switch. If both don't work, then yes, start with checking wires and connections for the Yellow wire...
But the front drivers turn signal will light it wont blink from the extra voltage. But that should eliminate the switch.
Jeff Penland
70_F100
Post by 70_F100 »
Nope, it doesn't eliminate the switch.
The front and rear lights are two separate circuits. (Actually, four separate circuits)
67 ford f100s rule
Well I must have made a mistake buying that lmc turn signal switch! Anyone have an idea where i could get a good reproduction one? Or is there sometihng I can do to fix the switch?
Jeff Penland
70_F100
Post by 70_F100 »
