heater switch
tynall44
heater switch
Post by tynall44 »
my heater switch wont blow on high : i replaced the switch so i know its the thing on the heter box i dont know what its called but how do you get to em to change them.... :? :? :? :fr: :fr: :woohoo:
basketcase0302
Re: heater switch
Post by basketcase0302 »
The "resistor" is on the backside of the assembly-held in by two 5/16" head screws, you can see it in this picture:
I'm not sure if you can pull it out without unbolting the housing or not? :hmm:
Anybody else been able to pull it out without unbolting the housing?
knightfire83
Re: heater switch
Post by knightfire83 »
The resistor doesn't do anything on high, it controls low and medium.
When on high, the heater switch supplies power directly to the motor, bypassing the resistor coils.
#270 would be high
#268 & 269 would be the other two speeds.
I would start by checking the wiring for #270 that runs to the resistor assembly. Check for corrosion or a broken wire. Also check to make shure the blower motor has a strong good ground, because high draws allot of amps.
If that's all ok, then suspect the new switch.
1970 Ford F250 4x4 ~ Sold.
tynall44
Re: heater switch
Post by tynall44 »
it blows on everything but high and both switches did it thats why i thought it was the resistor,,,,
70 ranger
Re: heater switch
Post by 70 ranger »
What about running a power wire to the motor itself and by passing the switch. There is a connector about 6 inches from the motor on the power wire.
1970 ranger 4x4
1965 mustang needs resto
flh shovelhead
rigid evo
