3rd brake light
71fordkid
3rd brake light
Post by 71fordkid »
has anyone converted thier cargo light to a third brake light? seems like it would be easy enough to do. i just had a thought about it, but then realized my stepside doenst have a cargo light :doh:
Ex Ford diesel dealership senior master tech (6 years)
Current bmw level 4 tech.
1972 Ford F100 Stepside - 302, forged TRW flat tops, performer 289 intake, edelbrock 600 cfm carb, CV IFS swap, 4.10 LSD disc 8.8 , AOD 4 speed auto. Currently 5 years in the making.
71fordkid
Re: 3rd brake light
Post by 71fordkid »
I guess i should actually search before i post my ramblings on here. has anyone done it though? id like to see what one that works looks like.
Mach428
Re: 3rd brake light
Post by Mach428 »
I suppose it would work, if you could find a way to use a red lens. It's a shame not to use a cargo light for the purpose intended as there are not many bumps with them
flyboy2610
Re: 3rd brake light
Post by flyboy2610 »
Mach428 wrote:I suppose it would work, if you could find a way to use a red lens. It's a shame not to use a cargo light for the purpose intended as there are not many bumps with them
Or you could just paint the bulb red. Be aware though that on these trucks, your brake lights double as your turn signals. Be careful where you draw power from!
Red Green
you'd better be right.
bluef250
Re: 3rd brake light
Post by bluef250 »
You would need to draw the power from the light side of the switch at the brake pedal.
The inside of the lense could be colored with a translucent coating.
http://www.createforless.com/Delta+Perm ... 11097.aspx
Other options include adapting a 3rd brake light with bed cargo light from a later model truck or a red light on either side of the bed light.
Kurt Combs
Re: 3rd brake light
Post by Kurt Combs »
Or buy a stop light that fits in your trailer hitch and runs off your trailer wire plug. I plan to do that as soon as I find one at a swap meet or online. All the ones I have seen are running and stop lights, I want just stop light so it will really standout when you hit the brakes.
Kurt
1972 F-250
TheEskimo
Re: 3rd brake light
Post by TheEskimo »
I saw one on here a couple years or more ago, somone had posted pictures of thier truck and had done this. I seem to recall it was a blue truck that was just painted at the time and the pictures were taken in a grassy field, but can't seem to find the thread now.
-Jason
1972 F250 Camper Special 360ci
1973 F100 Custom 390ci
1985 Thinderbird 302ci (DD)
