390 engine! I just installed duraspark and it was kind of hard starting this morning. When I got done with lunch it wouldn't start at all. All that's happening when I turn the key Ican hear the solenoid make noise and the negative side of the battery cable gets really hot and smokes. Ok so the solinoid was clicking so I switched it out with a different one I had in my tool box and that one made a mmmm noise. The starter isn't even turning the engine at all, so do you think I fried it and have to replace it. Are there any tests I can do? I'm thinking the timing was off is what caused this.
One other thing this morning it was more like a grinding start then starts, any info would be great thanks
Starter issue
Starter issue
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
Re: Starter issue
the negative cable is bad or loose. or maybe the ground from engine to firewall is loose or came off. buzzing of the solenoid menas theres not enough power going through the solenoid to the starter.
Re: Starter issue
I found the starter wire was stuck to the header and was grounding out. So replaced the wire and the problem was solved. Started right up after that. thank you fordman!
Re: Starter issue
Yea I know, and the thing is I didn't touch that wire when I did my install.
- newb70f250camper
Re: Starter issue
on my truck the ground wire from engine to firewall is hooked to a alluminum intake manifold will that ground correctly?
1970 f-250 camper special, 360, holley P/N 0-80457S (electric choke) 4v carburetor, edelbrock performer390 intake. I love my truck like I love my women.
Re: Starter issue
it should. you could add another on to the back or the head if your not sure.
