Battery discharging???
- CNM67
Hey yall my battery is discharging for no apparent reason im guessing its a short anyone know where i should start looking?
The iron never lies and 200 pounds is always 200 pounds
Re: Battery discharging???
remove the negative battery cable and put a ohm meter or test light between the negative cable and the negative battery post. if it registers or lights up then you have a draw. a light doesnt always work from what i found out. then you pull out one fuse at a time and see when the light goes out or the meter reads zero. when you find which fuse fixed the shorting problem. you trace down that circut the fuse controls.
- Aussie_1970
Dude I had that problem and traced it to be the New Process headlight relays (I had one on each side)
