Ground wiring question
- Calfdemon
I have pulled my F600 dash and am replacing my stock gauges (fuel, oil, temp, alt) with Auto Meter gauges (fuel, oil, temp, volt) for more accurate readings while keeping the F600 speedo. I have cut the metal rear housing where the stock gauges were and mounted my auto meter gauges in their place. I am currently doing the wiring and trying to re-use as much as the original wiring harness as I can while making the necessary changes (such as the alt to volt, etc..).
My question is this, since the f600 gauge housing is metal and grounded (the stock gauges used the housing as a ground with a ground wire going through the harness), can I ground my Auto Meter posts to the ground that was used by the stock harness? Does the location of the ground make a difference in the reading of the gauges or is "a ground a ground"?
The reason I ask is that the paperwork to my Auto Meter gauges tell me to run ground wires through the firewall to the following locations: Water and Volt to "a good engine ground", Fuel to the ground on fuel tank, and the Oil to an engine ground near the sending unit. However, I believe I have seen people that have done aftermarket gauges wire all of their grounds together and ground them to one location (which is what I would like to do). But I don't want to do this if it affects the readings in any way. Does anyone know for sure one way or the other?
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
Re: Ground wiring question
our trucks had the ground to the cluster to the dash support bracket behind the cluster. that oen black wire with terminal on it. and a 5/16 headed screw. the original gauges worked with one wire to the sender. and one wire coming from the ipvr. so that i show i would suspect that auto meter is talking about. each guage must have a ground to a terminal onthe back of it. or through the housing and the bracket that holde the gauge to the metal cluster. i am not sure you would need any ground. if the gauges ground through the housing and mounting bracket.
- Calfdemon
I figured pretty much the same thing. The Auto Meter gauge instructions are generic and probably worded for cars that dont have a good ground in the dash. I will just ground all of the gauges to the pre-existing ground location and see if they work on the first shot. If not, then I can do the extra work and wire longer grounds.
Thanks for the input...
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- Calfdemon
Thanks Fordman.. Wired everything up and installed the dash. All of the gauges work like a charm. Mighty nice to actually be able to see an accurate fuel gauge, water temp, and oil pressure. And the volt meter in place of the alt meter is nice... it actually moves and shows a result that you can read. Just grounded everything to the metal gauge housing from the F600 dash and simple as pie!
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- BobbyFord
Ok Rich, so where's the picsCalfdemon wrote:Thanks Fordman.. Wired everything up and installed the dash. All of the gauges work like a charm. Mighty nice to actually be able to see an accurate fuel gauge, water temp, and oil pressure. And the volt meter in place of the alt meter is nice... it actually moves and shows a result that you can read. Just grounded everything to the metal gauge housing from the F600 dash and simple as pie!
Absolutely
I believe you can see my ground wiring in this picture:
- stephen44
glad it worked out - which Auto Meter gauges did you use ? - how did you mount them to the dash ?
I have a 600 dash and will be doing this too - if i can ever finish body work
thanks
Stephen
Stephen
- Calfdemon
I should have taken pictures when I was doing it, but didnt. I have to take the dash off today because I want to change my Tach bulb to Green, so I will snap some shots when it is apart and post them here and you can see what I did.
I contemplated taking the Auto Meters apart and mounting the innards, but did not feel good about taking apart $250 worth of new gauges and possibly screwing them up, so came up with the method I used and it worked great! I bought Auto Meter Old Tyme gauges (black) and they look good with the stock F600 speedo.
This is the dash (not truck) I originally started with:
A while ago, I painted the dash and mounted an Auto Meter Old Tyme tach. I also moved my gas tank selector switch to the upper left spot on the dash, and my emergency flasher switch to the lower left of the dash. I put a second cigarette lighter in the location where the emergency flasher was originally. This way I have multiple power sockets in the truck. Here is a picture of it painted with the Tach in it (gas selector and emergency not shown):
And a picture of how the stock gauges sat inside the dash when apart:
I will go and work on it this afternoon taking it apart and will put some pictures of my modifications up in this thread later today.
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- Calfdemon
Ok, I had typed a long post and just about finished when my browser froze... so here I go again.
Before I show how I did my gauge panel, I will explain some modifications I previously did to my wiring so it is easier to understand how I ended up wiring my gauges. Previously when I was installing my stereo and additional components, I wired in 4 relays under my dash from the battery so that I would not have to over-tax my ignition wiring. With these 4 relays, I initially used three of them leaving one free for future additions (like these gauges). The original 3 relays were used to power my stereo, my second cigarette lighter/power socket in my dash, and a 3rd hidden power socket in my glove box which powers my iPod.
These relays are turned on/off from one of the 3 stock ignition slots. The other 2 ignition slots are used by my windshield wipers (just like stock), and my Tach. Here is a picture of my ignition wiring. The black wire is the on/off for my relays, the short wire with the female plug attaches to my Tach,and the other orange wire going into the back handles the windshield wipers:
Here is a picture of the 4 relays mounted under the dash above the steering column:
And here is the previously unused 4th relay plug which now powers my 4 new gauges:
To power my clock that I installed, I tapped into the stock cigarette lighter which is always hot. I also tapped into this wire for my stereo memory (radio stations/clock). Both the clock and the radio memory are low draws and the lighter wire more than handles this:
Now that the under dash wiring is explained, I will get into the gauge cluster. Here are a couple of before photos from the back prior to cutting out the holes for the new gauges:
Now here are after shots from each side once the holes had been cut, gauges had been mounted, and gaps had been sealed:
When I first cut the holes and put the gauges in, they were tight enough to basically hold them in place, but I used a few drops of Loctite Stik n Seal Ultra on each gauge to secure them in place (5 minute setting time). Once I had them positioned how I wanted them and set in place, I then sealed around each gauge with another Loctite product that is a rubberized adheasive caulking. I used this so that in the event that I ever need to remove a gauge for whatever reason, I can just cut the rubber seal without damaging the gauge or housing. I also liked that it dries white as the inside of my housing was originally white. Here are the 2 products I used:
I decided to use green lights in my Auto Meter gauges so I wanted to tint the light green for my stock speedo as well. I painted the inside of my housing with a hunter green so that it gives the light a green tint. i left the inside of the face white so it is still highly reflective with a green tint. I cant get it to photo well, but it is a nice green tint that goes right along with the green lighting of the new gauges.
Now for the wiring of the gauge cluster... Here is an overall view of the back. At first glance it looks like a bunch of spagetti, but it really is a simple layout and not as bad as it looks. The large black taped wad is the unused wires of the stock harness. I used the same sending wires for the fuel, temp, and oil (I replaced the stock sending units for Oil and Temp with the ones supplied by AutoMeter). I also used the same lighting wiring (blinkers, brights, gauge lighting), as well as the main ground (solid black) which grounds the housing. I did not use the old gauge grounding (black with white stripe) and those are taped up in that bundle along with the old Alt wires. The only reason the regulator is on the back still is to fill the holes where it mounts. I re-wired it with the stock wires in case it needed to complete some unknown circut in the stock wiring, but it serves no purpose with the new gauges.
Now for the other wiring.. All of the power wires for the 4 new gauges were wired together and attached to a plug which attaches to the previously shown relay:
All of the grounds (6 lighting grounds for the 4 gauges plus clock and tach, and 6 power grounds for same) are all attached to the two stock grounding locations used by the previous gauges:
The positive wires for the gauge lighting were attached into the stock lighting wiring. The 3 left gauges were attached to the left side wire, and the 3 right were attached to the right side wire:
And as for the wiring, that pretty much was it. Every gauge worked perfect the first time I hooked it up. My only intial concern with this method of mounting them was the 4 gauges being under double glass (the gauge housing, and the glass for the F600 dash). Once installed though, there were no issues. All 4 gauges are easily viewed during both day and night conditions. You dont even notice that they are under 2 pieces of glass.
Here are some pictures of everything installed and working:
Thats pretty much it!! Hopefully I made sense and your are not disgusted by my "do-it-myself" cutting, mounting, and wiring. I definately am no RobRoy (your stuff is awesome!!) but I get by. If anyone has any other questions, fire away. I learned as I went and I think it came out pretty well.
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- BobbyFord
That looks great, Rich. I like the old school gauges
- Calfdemon
Thanks Bobby! Its coming along little by little. Finally rebuilt the carb and now I dont have to worry about it stalling every time I hit the gas. Getting a whole bunch of 390 stuff and going to try and build a new motor for the truck. Might have to enlist your help on that one though. Never done it and dont know all the possibilities. I know you built yours and if I could do something half as nice, I would be happy!!
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- Calfdemon
Guess I should cut and paste this "modification" into another thread thats properly titled so others can read and follow it if they want. Can this thread be moved and retitled or should I just cut and paste? Ah, Ill just cut and paste the 2 posts...
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- stephen44
great write-up - thanks for doing that ! - Twice !
thanks
Stephen
Stephen
Excellent job Rich on the f-600 panel. I mounted my Autogage gauges similar (but i used epoxy).
Also like the use of the relays, I've got 6 of them is use in BC#16.
- Abrams
Guys, that f600 dash looks great. I was thinking about doing a custom fab dash, but this looks so good. Where did you find the F600 dash?
