Re: All gauges going all they way up, why?
This would be a sign to me that there is a ground in the wiring somewhere, (this is what I've always done to test a gauge to verify if it works or not) by grounding it out-it will travel to it's upper limit.The gauges are wired correctly now...now all his gauges go all the way up when you turn the key on
I'd go back to the wiring and inspect very closely.
Maybe TF and a few other guys can pipe in here also with some suggestions.
maybe the power is coming in on the wrong side of each gauge.
IPVR, (instrument panel voltage regulator), when these go bad, all gauges will peg out.
