Alternator????
Alternator????
Hey im 19 and not good with truck electronics...i got a 76 f100 with a 390 4speed 4x4.....the stock alternator was seizing up so i went out and bought a new alternator...since my recent purchase the battery has not been receiving a charge from the alternator. i put a new voltage regulator and checked all the fuse able links. the truck will run as long as the battery has a charge then it dies....i dont know what is going wrong!
Re: Alternator????
either the alt is bad. which can happen. even with a new one. or the wiring is hooked up wrong or messed up.
Re: Alternator????
just had the alt tested and its good....the wiring is all hooked up right....as far as i know.
Re: Alternator????
try this. charge the battery completely. once it is charged. remove the negative battery cable from the battery. put a test light or meter between the battery negative post and the cable. if the light or meter come on or move. then you have a draw on the system. make sure all the lights and radios are turned off. if you still have a draw. pull out one fuse at a time until the light goes out. which ever fuse controls the test light or meter to not show a draw. the draw is in the circut that the fuse controls.
Re: Alternator????
ok ill try that....how could it be losing that much of a charge though? the bat doesnt even get enough of a charge to idle for long after i jump start it
Re: Alternator????
It sounds like your battery is really low. It needs to be charged to a full charge with a battery charger, don't expect the alternator to do it. Have you have the battery tested? Maybe it is your problem, not the alternator.
69 F-100 Ranger 302
Re: Alternator????
the only catch is that ill end up finding if that is the problem by only one way....gettin all the way across town and then the battery goes dead and i wont be able to get it home(with out using AAA towing is). not the most ideal way to see if i have fixed my problems.
