new wiring???
Junior Knight
new wiring???
Post by Junior Knight »
I need some good advise..
I'm real tired of fixing this and that on my 67 because of years of *southern enginnering*..from other owners..
what would be the best place to get a complete wireing harness.. :cry: :pout:
1967 Ford F-100...goin back *STOCK*..just sayin
Junior Knight
Re: new wiring???
e z wiring or painless? or ??????
r3vo_3vom
Re: new wiring???
Post by r3vo_3vom »
im still in the middle of installing the EZ 21 i have had alot of other issues that have pulled me away from the f100 in the last couple of months but everything i have wired up was straight forward.
Matt
"I have as much authority as the Pope, I just don't have as many people who believe it." George Carlin
'68 F100 Ranger LWB 2wd 360ci C6
'75 Chevy 3/4 ton Flat Bed 350ci 4x4
'03 Yamaha Road Star Warrior 102ci
Junior Knight
Re: new wiring???
ok ..thanks..did it come with good instructions or what..and are u doing a full wiring job or just partial..
r3vo_3vom
Re: new wiring???
Post by r3vo_3vom »
I am installing the EZ 21, everything from headlights to taillights. I am still in the middle of wiring the dash. Every wire is labeled with what it goes to. The instructions are vague at best but a factory wiring schematic for your truck will help out. Make sure you keep everything you take out of the truck until you finish the job as insurance. There are some other threads here with some info/opinions on the wiring harnesses.
Matt
Junior Knight
Re: new wiring???
e z wiring it is then! thanks guys!
Junior Knight
Re: new wiring???
e z wiring for the 67 is on the way!!! can't wait... :D :hd: :woohoo:
mrsnicks
Re: new wiring???
Post by mrsnicks »
If you want high dollar and all the bells and whistles check out Ron Francis.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
