History: Bought this truck from the original owner in 1995ish. I have done a little here and there but last year I bought a travel trailer and I needed to put HER to work. Bought her some new tires and wheels and fixed all the little brake issues. I did some other regular maintenance and during the process of changing the thermostat all hell broke loose. I cracked the intake and broke the thermostat housing. Long story short, I DON'T KNOW MY OWN STRENGTH!!
So the journey began. May 2010 - I was heck, need to fix the intake so lets do the heads since they are the same since Regular gas. Was getting a little blow by. Thought to myself I don't like that lower end knock so hell lets get the shortblock done. So $3700.00 into the motor. New CAM, shortblock gone through, heads redone, everything mated and ported to match. I did not like the surface rust on the roof so I rattle can it white (Temp fix till full paint job).
Pulled the trailer around and found the battery would die while I was checking the trailer lighting at idle. November 2010 - Looked around here and found the 3G upgrade, done it and works great.
July 2010 with the hard pulling the carrier bearing on the driveshaft decided it was time to die. Had the whole driveline rebuilt to be ahead of any other issues.
December 2010 - Did not like the way the points were a pain in the arse to set so in went a Pertronics 1 - Why did I wait soooo long?
January 2011 - Been looking for a way to keep her cool and get rid of the "airplane propeller" strapped to the motor. I aquired a Lincolon Mark VIII fan from the junkyard and just fitted it today. I am waiting for the fan controller from DC Control to show up and I will finish it off.
I do not have before pics of her but other than the new wheels and white roof nothing has changed.... enjoy!!!
