one head light
- timmytim
one head light
Ok guys I got one for ya....I was working on my choke last night and after i got finished I hopped in to take it for a test drive.The head lights could not come on.All other lights where on but the two head lights where off... After looking under hood and scratching head a few times I shut hood and lights came on...Any ideas? Also anyone know where the head light relay is
buy'em dirty sale'em clean
get more money for the same
machine.....
My 1967 bump: http://www.fordification.com/forum/view ... 09#p668209
My 1970 Bump: http://www.fordification.com/forum/view ... 16&t=50726
- fordamericana
Re: one head light
I had that happen to me, mine turned out to be the ground behind the headlight wasn't grounding, so I had one light out, the other was dim... Best bet, pull the headlights out, and use a multimeter or test light to see if you got power to the light, and then check your ground wires if you do got power...timmytim wrote:Ok guys I got one for ya....I was working on my choke last night and after i got finished I hopped in to take it for a test drive.The head lights could not come on.All other lights where on but the two head lights where off... After looking under hood and scratching head a few times I shut hood and lights came on...Any ideas? Also anyone know where the head light relay is
The ground is lust a screw that goes through a lug on the ground wire into the radiator core support behind the headlight bucket...
I likes My FE I does...
Re: one head light
Check your dimmer switch also.
- Mancar1
Re: one head light
I agree with what has been said.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- timmytim
Re: one head light
thanks
machine.....
