This is what it looked like last May when I bought it:
The motor was pretty tired, so I compression tested it and only found 2 1/2 good cylinders. It did 65 mph for 55 miles with no problems, on these 2 and a 1/2 cylinders. It amazed me.
I pulled the engine the next day, and found 3 busted compression rings.
When I found loctite on the main caps I started worrying.
The head was in surprisingly good shape, though.
I had the block bored and the crank turned, with all new freeze plugs and bearings.
I ended up assembling and stabbing the engine in the same day, but the local parts house not having a timing gear set as promised, I was set back a little. At 3 a.m. the following morning I was hooking all of the accessory's up.
The next day I drove back to the big city, for college.
A few weeks later I started on the suspension, new king pins, coil over shocks, and all new bushings.
Next came performance parts, which actually gave me a 4 mpg increase in fuel economy.
Took a weekend for all the stuff to get put in, but I welded my own exhaust system from the header to the axle on the ground with no jacks, I won't do that again
I took it for a test drive, and found out that 85 mph was no longer all it had in it.
I've been driving it almost daily ever since, it gets all sorts of looks.
I recently started painting it.
You have to get creative when you're using a rolling shop compressor with a crappy air line, I felt like I was holding a mac10 when I was shooting the paint.
^ It's a slow work in progress, but it's getting there slowly.
Right now it's on hold because of college, I should pick back up progress around the first of the year. My plans are to lower it with DJM's kit with swaybars, possibly american racing rims. I'd like to go to four wheel disc brakes, I already have everything to swap the front minus a booster, and the same for power steering minus a pump and box. I recently aquired a 91 mustang roller shortblock and a aod-e transmission, so they'll probably go in it fairly soon for a little more power..
Here's what she sounds like
http://www.youtube.com/watch?v=lLVIseOl65A
