one wire alternator
- maverickfe
one wire alternator
Has anyone installed a one wire alternator and if so what did they have too do?
1966 Galaxie Convertable
1967 F-100 4X4 390
1967 Cougar XR7
1967 F-100 4X4 390
1967 Cougar XR7
- 70_F100
Re: one wire alternator
Check out the sticky posts at the top of the page...
That's not an oil leak
- fordamericana
On the 100Amp PowerMaster alternator. On a Ford application, one terminal on the back is wired to the hot terminal on the solenoid. The wire is 10 gauge from the original voltage regulator. The old regulator goes into the trash. The extra leads get capped and wrapped into the harness. And then you start the vehicle, and bring the RPMs up to about fifteen-hundred to excite the alternator and then check to make sure the vehicle is charging...maverickfe wrote:Has anyone installed a one wire alternator and if so what did they have too do?
This might help you out...
http://www.powermastermotorsports.com/f ... ators.html
For the argument of one wire vs. three wire...
http://www.madelectrical.com/electrical ... wire.shtml
General Alternator FAQ...
http://www.alternatorparts.com/FAQ.htm
3G Aletrnator thread from this site...
http://www.fordification.com/forum/view ... =8&t=13062
Hope the links help, best of luck to you...
I likes My FE I does...
- maverickfe
I bought a one wire on ebay its not the 3 wire one . So I just unplug the reg and hook up the one wire too the pos side of the battery? Going too try too get a hold of the person I bought it from.
1967 F-100 4X4 390
1967 Cougar XR7
1967 F-100 4X4 390
1967 Cougar XR7
- fordamericana
Yes, or the the positive post of your solenoid...maverickfe wrote:I bought a one wire on ebay its not the 3 wire one . So I just unplug the reg and hook up the one wire too the pos side of the battery? Going too try too get a hold of the person I bought it from.
