wiring wrap
wiring wrap
electrical tape melts off after a while and makes the wiring sticky after it falls off. is this the stuff i should use? would you use it on yours? http://cgi.ebay.com/ebaymotors/ws/eBayI ... AUS%3A1123
70_F100
Re: wiring wrap
Post by 70_F100 »
That's the stuff they used to use on factory harnesses.
It's tough to wrap correctly without doing it on an automated machine, but it will work fine if you take your time and make sure each successive wrap overlaps the last.
Have you considered the corrugated split loom? Unless you're going for a TRUE factory look, that would be my product of choice.
ForingaMex
Re: wiring wrap
Post by ForingaMex »
I used to work at a place that made the wiring harnesses for a Lincoln, I forget which car. That looks exactly like the stuff we used and the wrapping was all done by hand. I still have a couple of rolls of it that I picked out of the garbage bin.
-Jake
-02 Dodge Ram Quad Cab
-92 VW Beetle (Mexican)
BobbyFord
Re: wiring wrap
Post by BobbyFord »
After wrapping with the self-adhering tape you can cover with Powerbraid for a sano look: http://www.painlessperformance.com/webc ... ield=70902
Dragon
Re: wiring wrap
Post by Dragon »
What you guys call electrical tape us electricians call Marking tape or Phasing tape.
This is what electricians call electrical tape
http://solutions.3m.com/wps/portal/3M/e ... XJ738G1Xbl
Or this.
http://solutions.3m.com/wps/portal/3M/e ... XLTWRRM0bl
But this is what I do to racing harnesses.
http://solutions.3m.com/wps/portal/3M/e ... VRG3P95Jgl
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
Re: wiring wrap
yes both of those are electrical tape. i just want to wrap up my wires in the tape to hold it together so it isnt a mess. all of that plastic stuff and woven braided material is for show trucks of course. well the plastic coil stuff isnt. anyway. i fiugred that was the stuff that i posted.
Dragon
Re: wiring wrap
Post by Dragon »
The tape I showed will not come off and get sticky and messy. That is why electricians use it.
Old Fords Rule
My Gallery
Spark test
papabug71
Re: wiring wrap
Post by papabug71 »
I like the stuff BobbyFord posted. I think thtas what i'll go with when I get to that point :thup:
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
