67 dash lights
- randyvines
67 dash lights
I was wondering what the voltage should be at the pin for the dash lights? I have apx 6vdc at this location but the two lamps behind the gauges do not come on when the lights are turned on. the other lights on the cluster work ie.turn signals, brake light etc. Thanks
Re: 67 dash lights
The Voltage is adjustable via the rheostat in the light switch... as you turn the knob it will adjust the voltage to the lights to make them brighter or dimmer... (as long as the rheostat hasn't gone bad)
6V should be enough for them to light very dimly though... have you checked the bulbs?
- randyvines
Re: 67 dash lights
I replaced the lamps with known good ones, I am pretty sure the rheostat was turned down on dim I didn't turn it up while checking the voltage. I suppose that would have been a good to do.
- SteveC
Re: 67 dash lights
as a thought is the head light switch good? meaning the little wire that is coiled around the white reastat cause if thats wire is bad your dash lights wont work
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Re: 67 dash lights
how abotu a bad ground on the sockets. maybe they are just dirty enoguh not to ground to the metal base.
- randyvines
Re: 67 dash lights
