fordman wrote:take it to autozone they will test it for free.
Back in the days with generators this was standard practice.m-mman wrote:With the engine running, pull a battery cable. If the charging system is working at all the engine will stay running.
This is the best simple way to tell ,turn on all your accessories and speed the engine up a little, if it can maintain 14 volts you're good to go.m-mman wrote:Check the VOLTAGE at the battery WHEN THE ENGINE IS RUNNING. A 12 volt battery should show 12 volts but a functioning charging system should show 13 to 14 volts if it is charging properly
Fordman, all diodes are electronic...fordman wrote:i tthought the damage could only occur with the alternators with electronic diodes in them. but i dont know.
