emergency flasher switch
19mep81
Post by 19mep81 »
Can a 1970 dash mounted emergency flasher switch be used to replace a glove box mounted 1969 switch?
Re: emergency flasher switch
you should be able to . i think it will fit in the bracket. the plug is the same. so thats not a problem.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
You'd just have to partially unwrap or slit open the 69's wiring harness to get the wires to stretch over.
sport71
Post by sport71 »
:yt: I did it, and it worked fine.
Those who do not learn the lessons of history, are doomed to repeat it.
19mep81
Post by 19mep81 »
Thanks folks, really appreciate the info
