the neutral (park) switch over so it will start. If I reach down and hold the switch over I can start it.
thanks in advance
Sounds like it just snapped off. While you're locating a new pin, you can use some wire or a zip tie to hold the switch all the way to the left. The switch will act like the truck is in park, and you can start it. Just remember that the truck will start in gear while it's wired over like that.Kevin71 wrote:Man you guys are greatI beleive it has broken off there is something ehere but nothing that stick up
but will check it out
Thanks Again
