Now you guys are talkin' way over my head...
Does the meter itself draw power?
When I got my truck 22 years ago, it had a duel battery setup.
2 batteries, 1 alternator, and 1 battery isolater...
I used it like that for several years and never had any problems with dead batteries.
As of right now, I have it set up the same way, except everything is new.
Everything seems to work fine if I using it during the day.
It's driving at night like I usually am on the way home from an event.
The next morning both batteries are low and have approximately the same amount of charge in them.
I was gonna replace the master cylinder, 'cause it was leaking last weekend and take it Shucks and have the charging system checked out, but broke a brake line so I 'm kinda dead in water until I can get that fixed.
The meters are an after thought, but would really like to know whats going on with the system...
The amp gauge isn't working on the F600 panel, but it didn't work on the original cluster either.
This is part of the reason I want to install the volt meter.
If I hook up one meter to a keyed power feed and ground, that would read the primary battery circuit right?
Now, to hook up the meter for the aux battery circuit.
If I run a positve wire from the aux battery to a toggle switch then to the meter, then ground it, the meter would only be on when the switch is on.
I was looking at the solenoid, and couldn't figure out how that would work. I'm not much of a Sparky, but I'm learnin'.
An idea I had to remind myself that the switch for the meter was on, was to feed the meter light from the switch. Anytime the switch is on, the light would be on as well. It would stay on even when the key is shut off.
I'm just thinkin' that the alternator isn't putting out enough power to run the fridge, the head lights, and the stereo at the same time.
On the way to an event, only the fridge and the stereo and amp is running, one way home headlights are added to the equation. The alt that's in it now is a 65 amp.
I appreciate all the input..
KaptnKA
S
