My 72 Crew F-350 Cummins Tow Rig Project
- dolinick
Re: My 72 Crew F350 Project
Very cool. I am searching for a crew cab cab for an idea i've got. I would like to put an crew cab and long bed on my '68 F750 with F100 fenders and grille.
Dan
Dan
2003 7.3L F250
1968 F500 Utility Truck
Nice find madsceintist! When you get a chance, share some pics of your 73 crew too
1970 F250 Camper Special
- HRDROKN
Sure do like that red!
She looks to be in pretty good shape, but how can you really go wrong for $400. I say go for the Cummins conversion right off.... no sense in having to do things twice!
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
- TheMadScientist
HRDROKN wrote:Sure do like that red!She looks to be in pretty good shape, but how can you really go wrong for $400. I say go for the Cummins conversion right off.... no sense in having to do things twice!
Yeah I think she is just going to get a 460, Sorry reds not my color. My 73 dent still isn't done with the cummins ended up pulling it back out to run a different trans. The allison 545 is a piece of crap, I wanted to run an allison 1000 but I got an NV for FREE so I'm going to run the NV4500 instead. Anyway back to the bump crew my buddy already hooked me up with a 460 and I'd have to source up another 12valve and there hard to find around here for a good price.
2006 F-350 Crew Cab Lariat 4X4 6.0l Diesel Tow Rig
2005 Excursion Limited 4X4 6.0l Tow Rig
1977 F-350 Crew Cab SWB (4x4 soon)
1972 F-350 Crew Cab 4x4 SWB Cummins 12V, NV4500, NP205, HP60,D70B, on 35's
1966 F-250 Crew Cab (4x4 soon)
1965 F-100 SWB 351C 4v
1956 F-100 2wd SWB 429
1972 Bronco Explorer Sport
1969 Mustang Fastback (tubbed and caged, soon to get a 429)
1967 Mustang Fastback 427W, C6
1965 Mustang Fastback 347 FI HO, T5
- TheMadScientist
Here is some pics of the 73 Dent Crew, picked this one up for $500
This is what it looked like when I bought it, F-250 2wd
Chopped the 2wd out from under it.
Getting the axle ready to put under.
Axle under and ready to sit back on 4 wheels
Here's my cummins doner a 93 F-700
Retro fitting the cummins in.
My dog Auzzie posing with the truck on 35s
- TheMadScientist
Here's my 74 f250 4wd crew frame I finally dug it out of storage.
This what I'm going to put the 72 crew on
Nice Projects!!!
You are pretty brave working under those cinder blocks.
55F100
55F100
- TheMadScientist
The truck is now back together, I'm just waiting for the engine and front axle.
- TheMadScientist
I have decided to put the cummins in this truck and make this my tow rig.
Here's the NV4500 I found in a scrap yard, got for free. It's from a 98 chevy, converting it to a 2wd diesel trans.
Already got a cummins bellhousing and clutch slave/master cylinder setup.
Picked up a rear sump pan from a dodge for the cummins.
4" lift for a 99-04 superduty, putting these on the 72
Put a 78 dana 44 HP under it for temporary until I find a 60
The front 4" lift springs are on
The rear 4" lift springs are on.Used spring hangers off a 99 superduty from a local junkyard
Picked up a kingpin 60 for it from a 78 F250 camper special
The high steer arm for the Dana 60. "Blue Torch Fab Works"
Dick Cepek 35x12.50 R20 All Terrain on 20" Moto Metal 957s
Last edited by TheMadScientist on Sat Mar 27, 2010 11:41 pm, edited 3 times in total.
- zakt
- TheMadScientist
Thanks, Right now I'm waiting for the Dana 80 rear axle to get it back on 4 wheels.
So I can wheel it into the garage and start fabricating the motor mounts and front crossmember.
- TheMadScientist
Re: My 72 Crew F-350 Cummins Tow Rig Project
Here's a little update, changing the NV4500 from a 4wd chevy to a 2wd dodge diesel
The dodge input vs the chevy input shaft.
The new 2wd dodge diesel main shaft with 5th gear update
2wd dodge tail housing
Rear seat from a 94 F350 crew, picked it up from a local junk yard for $25
- AK F100
It's coming together real well. Looks great.
GPBFD Pyro Maniac
Daily Driver: 1974 F100 4x4 (ride'n on 8-Luggers) Build in progress
1997 F-350 Crew Cab 4x4, 7.3L Diesel SOLD
Pile-O-Parts: 1968 F100 - 2WD Shorty SOLD
Looking for a new project 57-60 Ford Truck
- HRDROKN
Looking great!
