wiring harness plugs
i replaced the wiring harness in my 67 f100,there are a few plugs that i dont know what they go to.is there a wiring diagram out that shows what each plug goes to.also needing info on wiring for the heater switch,its the one with the round knob
- Jay's67F100
Re: wiring harness plugs
i looked at the diagrams but i didnt see the plugs that im looking for,the ones i seen are the ones i already have plugged in.
- floyd67
post some pics of the plugs and maybey we can help
1967 f1oo "floyd"
2013 f-150 DD
2005 audi a4 (wife's car)
2013 f-150 DD
here are pics of the plugs
another one
- Roadrunner351w
After reviewing your pic's and reviewing the diagrams. Here is what I came up with
pic #1 Bl/green stripe --------power to all gauges from the ignition switch-----wire # 297 or 30 thru 30E ignition diagram ----it is probably just an extra wire if you need one
Pic#2 Green/black stripe ---- on my truck that wire if you ground it the brake light in the left corner of the dash comes on.----- and I also have a wire that color going to the bright and dim switch as well
Pic#3 Orange/Yellow and black ---- No answer yet
Pic#4 red/yellow stripe---------Should go to the bright and dim switch-----wire#15 on the blinker schematic
Blue ----------------------- Goes from the turn signal switch to dash---- wire #44 on the blinker schematic
that is what I come up with after reviewing all the diagrams
Roadrunner351w
i figured out the third pic,the orange/yellow stripe goes to the ins.cluster where there is another plug thats not plugged into any thing and the black wire goes on down the harness to the passenger side somewhere
my bright and dim switch is already plugged in though.ive looked at the wire color chart and didnt see any of the wires on there except the acc wire,the harness is out of a 68 f100
does anyone know of a diagram for a 68 on this site?
Look at the 69 diagrams, the 68 and 69 are the same... One thing to remember is that there are several different styles of wire harnesses in each year. It depends on the options the truck has (like full gauges, marker lights, camper wiring, etc...)
ok,thanks for the help
