Ok I got some thease are of my truck that I bought on Ebat and the guy said it was a good truck you know all that BS and when the cab swap started I found all this.
This My Professionally Installed Tranny. It Sarted Out With A 3spd On The Floor And In This Picture Was Afer They Changed It Over To Auto.
And Here's The Tranny Mount When I Got It There Were No Nuts On The Bolts
Also He Told Me There Was A Little Rust In The Floors But It Was Also Professonaly Fixed. All This Was Covered Up By Pices Of Intertube
And The Totally Awosme Battery Tray Fix
And The Dent Fix That Bondo Was Really Thick On Spot Was Almost Half Inch Thick And On The Bottom Of The Bed You Could See Where It Had Run Off The Bed A Dried Like That
The Rest Of Thease Are Of Custom Stuff I Found On My New Cab. The Story Behind It Is That The Guy Bought It From Told Me That The Guy He Got The Cab From Bought It Brand New And Took It Home And Put It On An International 4x4 Frame. Witch Is True Because I Have All The Recipts And Stuff From When He Bought It. Even The Orignal MO Tilte.
You Can See Where They Cut It To Fit The IH Stuff On The Tranny Hump.
If You Look At The Cab Mount You Can See There Custom Too.
I Guess The Had To Cut The Firewall For Something
And Were They Fixed The Neutral Saftey Switch
I'm Guilty Of This Rig Job
I Made Some Temp. Cab Mounts To Set My Cab Back Down On The Frame. My Welder Really Sucks So They Don't Look Pretty But There Still Holding The Cab The The Frame Till I Can Get The Cash To Buy The New Mounts And A Better Welder.
