I need to remove the headlight switch in my dash of my 68 F100, How is it done?
Thanks
How do I remove headlight switch
- michael69
Re: How do I remove headlight switch
Reach under dash and fill switch you will find a button that pushes in. While pushing button pull on the switch knob and wiggle it while pulling. The knob will come out with stem. Then you just unscrew the trim ring from switch and push out of dash and unplug. You may have to try several times to get knob and stem to release they stick sometimes.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Here is a picture Keith has that shows the button to push to release the knob.
Are the ignition, wipers control and ignition taken out the same way?
- Lar4t9r
Nope, light switch is the only one.67_F100_390 wrote:Are the ignition, wipers control and ignition taken out the same way?
you have to remove the wiper knob with a allen wrench first before you remove the three tabbed ring from the front of that switch.
- Lar4t9r
Fordman is right...sorry, I should have mentioned that.fordman wrote:you have to remove the wiper knob with a allen wrench first before you remove the three tabbed ring from the front of that switch.
