THE INSTRUMENT PANEL LIGHT FOR THE SPEEDODOMETER DOES NOT WORK?
WHAT WILL IT BE OR HOW CAN I FIX IT?
1972 INSTRUMENT PANEL LIGHT
- peanutman
Re: 1972 INSTRUMENT PANEL LIGHT
Pull your cluster. It should have little twist in bulb holders on the back. Probalby just a bad bulb. Look at Keiths tutorials at top of main page, should have some pics to give you an idea on what your working with.
http://s533.photobucket.com/albums/ee33 ... e_Johnson/
1970 302,ps, ac, 3 speed o.d.
Here is a closer picture of how they are mounted. just turn this black knob 1/4 - 1/2 turn counter clockwise and pull it out, then replace the bulb. The bulb will be attached to this black knob. My advice is to replace all the bulbs while you are there as the others are probably getting ready to go, or will as soon as you put it back together.
