Throttle Linkage
theogre5150
Throttle Linkage
Post by theogre5150 »
Ok. Here is the current thorn in my side of my engine rebuild. I installed an offy intake on my 240. I have a Holley 2300 2bbl carb. I have an adapter plate in place to mount the carb to the intake. In doing this I had to turn the carb facing sideways instead of facing the front. Now I need some type of linkage to make this work. My original setup had a 1bbl carb and it required linkage to make the side to side motion. I tried using this old linkage but I ended up messing it up. Is there a linkage/cable setup out there that would work with my setup or do I just need to upgrade to a 4bbl?
craftsman
Re: Throttle Linkage
Post by craftsman »
Look at some of these cables and see if they might work. These are for carburated engines but maybe one from fuel injection may work, you may have to fab some brakets to make it work.
http://broncograveyard.com/bronco/c-625
Here is a cut to fit cable.
http://www.jegs.com/p/Lokar/749864/10002/-1
http://www.jegs.com/p/Spectre/767135/10002/-1
Dragon
Post by Dragon »
theogre5150 wrote:Ok. Here is the current thorn in my side of my engine rebuild. I installed an offy intake on my 240. I have a Holley 2300 2bbl carb. I have an adapter plate in place to mount the carb to the intake. In doing this I had to turn the carb facing sideways instead of facing the front. Now I need some type of linkage to make this work. My original setup had a 1bbl carb and it required linkage to make the side to side motion. I tried using this old linkage but I ended up messing it up. Is there a linkage/cable setup out there that would work with my setup or do I just need to upgrade to a 4bbl?
finally found this (we used these in the old days to flip the pattern sideways or in your case back to normal):
http://store.summitracing.com/partdetai ... toview=sku
[attachment=0]ofy-5832_w.jpg[/attachment
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
My Gallery
Spark test
