"Complete" turn signal switch.
bluef250
Re: "Complete" turn signal switch.
Post by bluef250 »
Try Shee-Mar, Inc. The turn signal was almost an exact duplicate of OEM. Only difference was one wire was a different color.
http://www.shee-mar.com/start.html
http://www.shee-mar.com/shop/catalog/order2.html I installed an SM41F 67-72 F100/350 before G30.001 w/o cruise. $49.77. Prices have done up, no surprise.
Shee-Mar
Turn Signals Switches, Cams & Accessories
PO Box 179
Longmont, Colorado
80502
Fax:
888-627-8876
Phone:
303-678-5334
E-Mail us at
sheemar@shee-mar.com
A little jewelery's screw driver worked for me to release the wire from the connector. The manual shows a small diameter tube with slot to use to release the barb.
DGrant09
Post by DGrant09 »
I just picked one up and ended up not needing it.
There is a pin tool that helps remove those little guys. I wish I had one to fit these!! A local auto electric store may carry them.
Here is a link for LMC-
http://www.lmctruck.com/icatalog/fb/full.aspx?Page=100
Here's a link for Dennis Carpenter -
http://www.dennis-carpenter.com/pdf/67-79_2008.pdf
Dan
09", F350, Cabelas, 6.4L
72", F250, CS, 390, 2 WD
DuckRyder
Post by DuckRyder »
NPD also carries them...
Fordlorn
Post by Fordlorn »
$25.00 from Dennis Carpenter Ford parts. :D Just ordered it.
Rednecks, white trucks and Pabst Blue Ribbon beer!
Corkwheats
Post by Corkwheats »
Fordlorn wrote:$25.00 from Dennis Carpenter Ford parts. :D Just ordered it.
Really? I looked, and it was more than that. Maybe they don't like me.
71 Ranger XLT LB 2WD
Tilt Steering, West Coast Mirrors
390, 9.5-1 C.R., Holley 600, D2 Heads, C-6
Custom Grind Oregon Cam
Flotech Headers, 2.5" Duals w/H-Pipe
mrollings53
Post by mrollings53 »
Maybe that was because he posted over four years ago.
Corkwheats
Oops! I had a Benjamin Button moment. My bad.
