Redoing my blinkers need a lil help
yogi_pahl
Post by yogi_pahl »
So im totally lost eve trying to use the wiring diagram it's not helping and i need to get the trunk on the road asap. What would be the EZ way to redo all of the blinkers light on and stop?
yogi_pahl
Post by yogi_pahl »
Well I went out and i do have light when i turn on my head light but nothing else the back up wear rewired to a switch. I found one flasher that was behind the gauges attached to a metal frame thing but was not plunged in and didn't work anyway. Could i jump the two wires that i think wear hooked to the relay and what two pin would i jump to by pass the turn switch. I can get pics if that will help.
yogi_pahl
Post by yogi_pahl »
also the head lights and high beam switch,wiper both speeds, heater both speeds and cig lighter all work fine.
