no horn
no horn
looks good, fuses good, do the horns itself go out, the horn button looks a little bent. could that be it.
THANKS
re: no horn
Some good info on horn stuff here
http://www.fordification.com/forum/view ... c&&start=0
Were they working before? The average problem is the relay on the fender by the battery going bad. When you hit the horn button you should be able to hear it click if just the horns are bad.
If you need more info or questions after reading that thread let us know.
- 1971ford
there are ttttttttooooooons of threads on this that show all the problems it could have, but ill try and help out alittle..
push the horn button in and turn it to counter-clockwise so it comes off. look in a hole thats under there and there should be a little spring/brass contact. if the brass does not feed allthe way through the spring to the other end, then its bad. if its not there, thats probably the problem as well.
the horns do go bad as well. i just threw my boss's horn out because it was bad and replaced it. now it works.
could also be wiring. could also be ground connections.
-Ryan
