Removing Armrests ?
- wildcard
Removing Armrests ?
Before I force a socket in my armrests, I would like to confirm what size socket it takes. I remember in the 67 I got one stuck inside. Don't want to go through that again. I tried a 1/4 in. drive deep socket a little ways but I don't think it will even fit without forcing it. Any advice will be definitly be appreciated.
- floyd67
re: Removing Armrests ?
my were star head screws
- seattle67
Im at work
so I cant run out and check, but I think you're correct, as I recall they are 3/8.
Nut drivers work slick for getting those off, no getting your socket stuck.
Dan
- kilog55
yeah 3/8 on my 72 i used a deep socket with a 1/4 drive
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
- wildcard
Thanks everybody. Just so happened, my old running/drinking/getting in trouble buddy stopped by that I haven't seen in a long while and had a nut driver in his toolbox. Since we gave up the old ways we don't get together as much as we should. He's more of a brother to me than my blood kin. But once again he saved the day.
BTW, it is 3/8.
BTW, it is 3/8.
- rjewkes
yeah get a deep socket it won't get stuck and ditto on the 3/8" size.
- Underdog97
Are you replacing the armrests or just taking them off. OK guys I'm going to let you in on one of my trade secrets here. The snub nose econoline vans use the same armrests as our 68 to 72 trucks and are a lot more plentiful in the wrecking yards. I sell a lot of them on Ebay almost as fast as I list them!
- SteveC
ill tell ya it is 3/8 i took mine off today in fact...used a 1/4 drive deep socket and a 3 inch extension and took a bit of time to get the socket to wanna go on there but they will come off
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- wildcard
I got mine off and painted it. It was a funky gold color and I painted it white since everything else except the passenger side panel which has to be painted now. Only problem is the interior is the Wimbledon White and the doors are BRIGHT white. Now I have the incentive to redo the entire interior. So there's my summer project.
- seattle67
Hey Wildcard, if they're not torn or damaged you can clean them up and paint them with vinyl spray paint. You would probably be surprised at how nice they come out.
Dan
- ford4x4fun
Walmart has it, and it workd good too. Just make sure you clean them up good, and I put a couple cotes on the stuff I have painted... Turned out nice. I am painting the brown set that I got from Teacherman gray, when I get home... Mywildcard wrote:Where can I pick some up? Also, how durable is it?
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
- Underdog97
$15.00 + $8.95 shipping is what I would ask from Fordification memeber for a set that has no rips or tears and are ready to bolt on. I have a pair of Factory black ones. I might also mention that with dying them ( as I do that as well.) that it's easier to dye a light colored set dark rather than a dark set light. Also to use a quality dye not Plasticote (The official spray paint product of NASCAR) as it will flake off no matter what it says on the can. It may take a month or two but it does flake off. I would and do use a product called ( SEM vinyl dye) and use my spray gun to apply three coats. It's the best on the market and is what Body & Paint shops use to dye the vinyl & trim replacement pieces on cars.
