I know this isn't the safest thing to do, and the cops probably wouldn't like to see it either, But I was thinking about taking an antique bottle and using it as a water level, that corrisponds with my fuel tank. Basically it would be a direct reading of how much fuel I have. Wanted to know what everyones thoughts are on this. The link I am providing is actual water level, a little more than what I would need.
http://www.factsfacts.com/MyHomeRepair/WaterLevel.htm
Basically I would need a flued line, and an air line running back to the tank, and than mount the bottle to the dash. Sor of a Rat Rod, kinda thing, but I have nothing but time to sit here and ponder ideas. So What do you all think!!!
Water Level Theory for Whiskey Bottle In Cab Fuel Gauge!
- ford4x4fun
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
- seattle67
re: Water Level Theory for Whiskey Bottle In Cab Fuel Gauge!
Well sure, it would work to a certain extent, and look really cool. But if you got in a crash it would turn you into a blow torch.
I really hate being negative to such a cool idea, but I just cant picture a way to make it safe.
Don't give up on it though, this requires a brain storm!
Dan
- ford4x4fun
I was thinking maybe a plastic whiskey bottle, good stell tubing, and than this set up just outside the fuel tank. I think I could wire it so that if I lost power for any reason it would shut off...
http://www.rvpartscenter.com/ProductDet ... 454&SID=32
This isn't quite the right thing I just haven't found the right one yet... Still looking!!!
I have been sitting here brain storming!
US ARMY Retired
US ARMY Retired
- ford4x4fun
Ok I found the right thing to shut the fuel off...
http://psa.manufacturer.globalsources.c ... -Valve.htm
Now I just need to find a way to keep the bottle from coming apart in a wreck... Don't know if that is 100% Possible, but maybe a way to make it safer!
US ARMY Retired
US ARMY Retired
- ToughOldFord
That's too dangerous. Remember, gas isn't just flammable, it's an explosive. Even just the small amount in the bottle will send enough shrapnel in your eyes in a crash to blind you for life even if you survive.
If your gauge doesn't work just get a long stick.
- ford4x4fun
I actually saw this on a TV show (Hot Rods or Something) a while back... I know it is possible, and I know it isn't the safest thing in the world, but then the fuel tank is right behind the seat anyhow. This is just an idea, and maybe just something I will implement to work while it is sitting there, or I might not put it in at all. I was thinking I might be able to do it with a float in the tank as well. So what was in the bottle was actually just water or something. I believe that would be possible as well. I will have to look more into it, and if anyone has some more ideas that would be awsome as well.
US ARMY Retired
US ARMY Retired
- ford4x4fun
