what is under padded dash?
- Kurt Combs
I was thinking that I might just remove my 72 bump's padded dash and go with all metal. Does that dash look ok under all that padding and vinyl?
Kurt
1972 F-250
1972 F-250
- kaptnkaos
re: what is under padded dash?
- l1k2gadd
My Bump was "Dashpad-less" when I got it. I believe the sun faded the heater control illumination plastic from all of the exposure to the southern sun because it looks whit-ish with the headlights or parking lights on. My instrument panel lights are whit-ish colored too (unless they are supposed to be), not green-ish like all of my other vehicles. I found one of those carpet dash-mats in a '72 that had a Semi-Holes embroidered patch in the center section of it that I removed from it. I think the dash looks better covered. I am inactively looking for a good dash pad for mine and when I find one I will remove the dash-mat.
- SteveC
that sounds a little to far from the truth
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- Kurt Combs
Fordman, I will run out and look under my dashpad asap....just in case.
Kurt
1972 F-250
1972 F-250
- 1971ford
and if you decide to go without a dash pad, make sure you tear the defroster vents out of the dash pad and use them on the metal dash. they have screw holes and everything to put them on the metal (did ford make the screw holes purposly for people not wanting the pad
here is what my 71's looks like:
i think it looks awesome without the pad. id weld up the wholes but i dont have paint.
-Ryan
I found a ballpoint pen my mom stole from the government when she used to work for Social Security years ago under my original dash pad. It still worked.
I stared at the dash for about 10 minutes without the pad, but I decided to put a pad on it.
1972 F250 Crew Cab
Family heirloom
Photo gallery: http://www.fordification.com/galleries/ ... ?cat=10482
Family heirloom
- Underdog97
Some of us get all the breaks, I wish I'd of found $100.00 bills lining the underneath of my dash pad, all I've found so far has been petrified ants and a couple of bee carcasses. Fordman must've got DB Cooper's old Ford truck, And we wondered where he hid all of that money from the Hijacking, it was under Fordman's part's truck dash all these years (LOL) Can I come over and check behind the gas tank?Please!
- MadMaxetc
I have mine off and like it, but I would put a nice one on if I found one.
You also might want to check to make sure it is legal to take it off in your area. Some placees require it, as it was there for safety. (head impact)
Dan
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
FORD Girl
Photobucket Pictures
FORD Girl
- ezernut9mm
- kilog55
so how do you remove it? cause mine has the big crack in the middle and the PO tried to fill it in with something that now looks like sheetrock/drywall
1968 F250 Ranger 2wd 472ci TH400 Caddy powered.
1979 F250 Ranger 4X4 400ci T18
anyone need a 60x24x24 flatbed semi toolbox?
my gallery - http://www.fordification.com/galleries/ ... ?cat=10437
- 1971ford
I hope you have small hands
there are just nuts holding it in. but, theres a bunch. scattered on the underside of the dash, there are many nuts that you just have to get to with a wrench. there is one hard to find hidden nut on each inner corner of the pad on the drivers and pass. side. dont forget those.
i think there are 14 nuts.
-Ryan
