turn signal flasher "update"
- floyd67
does anybody know what wires go to the turn signal flasher i put all the wiring back in the truck and that seems to be the only thing i can't figure out thanks
- kaptnkaos
re: turn signal flasher
Hey floyd67,
The 2 wires going to the flasher primary flasher are
#8 = orange/yellow stripe
That's the power feed that originates at the fuse box...
it makes a couple of changes between the fuse box and the flasher unit.
#44 = solid blue (can be either light or dark blue but has no stripe)
Circuit 44 feeds the turn signal switch.
The wires should be connected to a two hole female connector that looks like an "L" ...
Hope that helps...
KaptnKA
S
Hope that helps...
KaptnKA
- floyd67
i don't have the orange wire #8 and the blue wire is attaced to my emergency flasher with the white /red stripe in a factory connection is it possible the turn signals and emergency is on the same flasher
- floyd67
from what i am reading in the diagrams '67 is different than the rest any help would be great thanks guys
- kaptnkaos
Hey Floyd67
It should have dawned on me that you were working on a '67 buy yer name...
Looking at the 67 wiring diagram, it shows circuit #8 going from the wiper switch to connecter "L" where it turns into circuit # 297 which is the black wire with a green stripe that goes to your flasher unit.
However it doesn't list a color for circuit #8.
It is tied to circuit #950 on the wiper switch, which is listed as being black on the wiper & washer diagram. If you can locate circuit #950 on the wiper switch you can tell what color circuit #8 is...
Circuit #44 which also goes to the flasher is still a blue wire...
Hope that helps...
KaptnKA
S
Hope that helps...
KaptnKA
- floyd67
thanks for your help but i think i need to find a '67 to look at to compare
did you figure out your wires yet?
If i can get pics onto computer i will try to post mine, they are hanging under dash in the replacement flasher. I know 1 is white /red stripe, located just to the right of the column. and there are total of 3 wires. 2 connectors.
67 F100 240 I6 3spd now gone
1971 F250 LWB FE power by FORD
- SteveC
on my 67 (and this is from memory as the truck isnt near me) i had one orange and one light blue(i think)
But from the life of me i had so much trouble with mine the whole cirrcuit wasnt getting power...i ended up making it powered with a switched 12v line and inline fuse...as all the wiring and connection checked ok ...but on my 67 it had 2 different flashers....
Maybe if Thunderfoot chimes in here he could tell you..he is really good with the electrical on these trucks
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
Floyd, not sure what exactly your after, but I took the 67 wire diagram and edited it so that only the wires for the Flashers are in the diagram. The colors on the diagram are for illustration purposes only, use number and color code on diagram.
There are two flashers, the one for the turn signals is mounted to the back side of the instrument cluster....
Here is the Diagram, click it to expand...
- floyd67
i have one flasher with white/red strip and blue wire in factory connector and red/white strip and red wire in the other factory connector orange wire/white stripe goes from ignition to wiper switch no flasher on instrument panel and i have two panels both the same unmolested i found a untouched '67 to look at waiting for a call from him so i can look at it for comparison
thanks for the help i will let you guys know
- kaptnkaos
Just FYI floyd67...
The regular flasher may or may not be connected to the instrument panel, it could be just hanging loose some where behind the panel.
If I'm not mistaken, the orginal flasher units were in a plastic housing with a nub on the top that stuck into a hole in the back of the panel.
If it has been replaced (which after 40 years you can pretty much assume that it has) the metal ones don't have the nub so they just hang loose from the wiring harness.
KaptnKA
S
KaptnKA
- kaptnkaos
Hey Thunderfoot...
How'd U do that...
There are some circuits listed on this one that arent listed on the one posted here...
This one's alot easier to read... can U do that for a '68 ???
KaptnKA
S
How'd U do that...
KaptnKA
Re: re: turn signal flasher
You like that...kaptnkaos wrote:Hey Thunderfoot...
How'd U do that...
KaptnKAS
I think the 68 is the same as the 69, I will take it and work it this way and send it to you. Gives me something to do at work...
- xxxtina63
Umm, no disrespect to anyone, but I had to change the turn signal flasher out on my 67, and while I don't recall what color the wires were, I can tell you it wasn't mounted on the instrument panel, nor did it resemble any flasher I've ever seen before. It was mounted on a brace, (kind of like the one you see when you pull the radio out), behind the instruments about half way to the firewall. Was a black box about 2 1/2" square and about 1 1/2" tall. Pain to get out! Couldn't find any info at the time so I cut the wires off at the box, put connectors on the ends, and plugged in a late model style flasher and it's worked ever since. Maybe mine's just an oddball and I just got lucky on the hook up.?
My FORDification Photo Album
- rjewkes
you looking to find the flasher connectors or the dash to wheel connector? sorry if q doesn't help.
no tripx i remember now keith mentioning this big bulky flasher.
