ignition switch removal from 1971 f-100
how do i remove this switch...i see the hole on the faceplate, but cannot figure out how to use it to remove the switch...i do have a key.
re: ignition switch removal from 1971 f-100
To remove the ignition switch lock cylinder: First DISCONNECT THE BATTERY! Then put the key in and turn it to the 'Accessories' position. Stick the end of a paper clip into the tiny hole in the face of the lock cylinder to release it and then turn the key counterclockwise and pull the key and lock assembly out of the switch. Installation is opposite of removal.
thanks!....just put it in...very easy...thanks again.
I would have never thought of that!
- Crackpot
- cghstrojan08
Wow, so much knowledge.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
