Anybody wired MSD to Duraspark II?
Alfred Lord Tenniscourt
Post by Alfred Lord Tenniscourt »
I am wiring up an MSD ignition computer to a duraspark II distributor. There are three wires from the duraspark, none of which match the MSD wiring diagram, and there are only two inputs that he MSD needs. I am assuming that I wire up the two sides of the pick-up coil, and that the polarity doesn't matter. If I am wrong, I would really apreciate it if someone would pipe up before I trash my stuff.
Actually, I would apreciate it if someone would tell me I am right too. It would calm me down some...
72hiboy4x4
Location: As far away as I can be from Wa state, without crossing the Mississippi
Post by 72hiboy4x4 »
(Note: this is on my CJ, but kinda related)
My Cj-5 uses an electronic pickup dizzy, a late model Ford style MSD Blaster TFI coil and an MSD Off-Road ignition box. I only used 2 of the 3 wires off the dizzy to fire the ignition box, so you should be on the right track. The dizzy just acts as a trigger, so you shold be fine.
(take this as freely as its given, it is possible I'm wrong, but it did work for me)
72hiboy4x4
hers a pic of my set-up. You can just see the way the wires are tied into the dizzy.
re: Anybody wired MSD to Duraspark II?
Well, she fired up ok, so I guess we were right. I wasnt sure if there was an actual negative and positive side to the pick-up coil. Theoriticaly, I can't see why it would matter, and it either doesn't, or I just got really lucky on my first try putting it together.
I suppose the third wire is a ground, and the first two see a difference in voltage that triggers the MSD.
Thanks for the help.
That jeep looks like it probably runs pretty strong by the way...
72hiboy4x4
she runs out pretty good, thanks!
Glad it worked out for ya, I had the same question when I set mine up.
here's me playing around right before I packed it up to move to OK.
BobbyFord
Post by BobbyFord »
