What stinks?
What stinks?
I've never owed a vehicle with the gas tank mounted inside vehicle, can you smell gas inside these trucks?
- cathynkeith
it can also stink if the fuel sender is loose and leaking, like when the body shop paints the inside, pulls the sender and fails to tighten it down and you fill it with fuel only to have a possible bomb on your hands because you have all new weather stripping and door sills. Oh and you do not notice and leave it parked inside you business all weekend and come in monday to a very heavy fuel smell throughout the warehouse, good thing you notice before flipping on the breakers, I was even scared to open the manual roll up door thinking I could cause a spark. (not that this has ever happened or that someone would want their insurance company to find out....)
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
re: What stinks?
For some reason my wife gets nervous when she rides in the truck. I go around a corner and the half tank of gas slams up against one end.
RON
Excuse me while I whip this out
- cghstrojan08
re: What stinks?
Mine used to stink. I thought it was the neck. Found out I had a bad fuel pump. That is how bad it was spraying everywhere.
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
Member #1076
1968 F100 SWB 360
- ezernut9mm
re: What stinks?
This is a real easy fix that I'd take care of for sure!leak around the sending unit
In dc's catalog: Truck Bronco 4x4 1966-1979 Fuel Tank Sending Unit to Tank Gasket C0AF-9276-A 1.00 Each
I drive a chebby van for work that is awful for pulling exhaust from outside into the cab!
Oh well, there go a few more brain cells!
- 69rangerman
re: What stinks?
Couple of other things...
I just settled a very small leak around the threads at the fuel pump - it was leaking enough to drain the line from the carb and cause me 3 or 4 30 second cranking session in the morning to pump up the lines again.
Also, if there are holes in the bulkead that aren't sealed up and the carb seeps at the gaskets or is rich you'll eyes will start to burn as it blows back into the cab.
Good luck!
Good luck!
"O say, does that star spangled banner yet wave? Oer the land of the free and the home of the brave?" It does at my house! God bless America!
- AlleyCat
Re: re: What stinks?
When I had a bump as my DD I got pretty good at using the slam as a substitute for a working gas gauge.Well, okay, I got pretty good at it AFTER I walked a few times.bugser wrote:For some reason my wife gets nervous when she rides in the truck. I go around a corner and the half tank of gas slams up against one end.
Clay
re: What stinks?
thats why I used to love riding in my truck as a child, all kids like the smell of gasoline, or maybe thats just a west texas thing. I ended up having mine fixed...now its just musty...and I get 4 more truck lengths worth of milage.
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
