My speedo has wires!!!!!!!!!!!
Hey everyone,
OK, on my speedo cable, located about halfway up my firewall is a little disk-like thingy built into my speedo with 2 wires coming out of it. the two wires go into the wiring harness....never to be seen again!
Just in case there is a difference in vehicles, its a 70 2wd f100 302 c4 california built truck.
Thanks, Steve
Thanks, Steve
re: My speedo has wires!!!!!!!!!!!
hey,
Nah dude, its on the other side of the firewall (engine bay) its inline with the cable, like a sensor or something
Steve
Steve
Steve,
Just had to do it!
Would like to see that.
Just had to do it!
It's not for cruise control. Ford never offered cruise on these trucks. Here's the part you're referring to, correct?
It is a NOx device (part of a system called TRS or transmission regulated spark) that only allows the vacuum advance to work under certain conditions. When the outside temperature is below 60 degrees or so the vacuum advance is allowed...when it's above that temp, the vacuum advance is only allowed when the vehicle is traveling around 30mph or faster. The hardware and wiring to do this varied from '70-'72 but basically you have a temperature sensor on the driver's door pillar, a sensor on the transmission and a control module with a solenoid valve for the vacuum. For automatics the transmission sensor is a line pressure switch and for manuals it's just a mechanical switch that tells when it's in high gear. The control module switches the vacuum source on or off to the vacuum advance depending on the temps and/or speed. This emission system is a 'tack-on'Â
- MaxKlinger
Just had a big "Ah ha!" moment. I have the temperature sensor on my door frame. I thought it was from some kind of aftermarket security system installed by a previous owner. There is also some kind of relay mounted near the passenger side valve cover, I thought that was supposed to be part of the emissions system.
I still haven't passed NJ state inspection yet because my emissions are bad. I gave up, when I get Pennsylvania tags in Jan I should get a nice "Exempt" sticker and all will be well.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
- MaxKlinger
It looks just like the "Thermal Switch" in Keith's post above.
Tony
Wow!
That is some crazy stuff right there!
Never saw it before on a Ford.
Fordman, I didn't think our bumps had any kind of pollution control, (other than PCV if it's considered polution control)?
Basketcase
Basketcase
well they did have a can on the frame of the 72's to revent the gas vapor back into the gastank. and i once again wasnt thinking about that temp sensor correctly. it doesnt have anything to do with the smog stuff. i had been looking for kieths pic in another thread and then i finally saw it open in this one.
