Will these seats fit a bump?
uboughtwhat?
Post by uboughtwhat? »
I went to the junkyard today looking for a seat. I found a really nice split bench seat in a 1988 Mercury Grand Marquis. Has anyone tried to put a seat like this in their truck?
FORDification
Site & Forum Admin
Site & Forum Admin
re: Will these seats fit a bump?
Post by FORDification »
Any seat could be installed, but none will be a bolt-in. It's going to require you to fabricate mounting brackets. However, any Ford truck seat up through '96 will be a bolt-in using your existing bracketry. Take a look at this page:
http://www.fordification.com/seats.htm
uboughtwhat?
OK, well now here comes the challenge...I found a perfect bench seat with the center armrest in a charcoal gray color.....it came out of a 98 F-150. Has anyone fabbed the brackets to make this work or should I take pictures along the way to make a new tech page topic?
Thanks,
Banjo
Post by Banjo »
Sorry to hijack, but Jeff, I agree, drive F-150 daily (2000) and the split buckets with fold down console are very comfortable and durable.
the brackets on ford seats arent all that different fromyear to year so it wouldnt be all that hard to make any ford truck seat fit into another ford truck. imo.
19674x4
Post by 19674x4 »
Any ford truck seat up to 96 will bolt in mith minor drilling just like keith said. it just a matter of lining up the bolts to the new rails on the seat and drilling a hole. and stickin a nut on it.
My Photo Album
Tim P.
Post by Tim P. »
Didnt I see an article somewhere on this as to someone doing it and posting pics of the switchover? I just picked up on a seat out of a 95 Eddiebauer truck for my 72 for $50 and they pulled it for me no damage either and its a light brown tooboot with the arm rest cup holder and the lumbar airbags :thup: and tech article would be a nice reference to check out.
Tim P.
MadMaxetc
Post by MadMaxetc »
check out my website. I did the hard way and used the 94 tracks and it still only took me an hour to do.
Dan
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
FORD Girl
Photobucket Pictures
Tim P.
Post by Tim P. »
So you only had to bend the passenger side bracket to clear the tank correct? Can the seat adjustments and handle be retro fitted to the existing mounts off the newer brackets ie cable, handle, cable springs etc. to our older mounts.
MadMaxetc
Re: re: Will these seats fit a bump?
Post by MadMaxetc »
Tim P. wrote:So you only had to bend the passenger side bracket to clear the tank correct? Can the seat adjustments and handle be retro fitted to the existing mounts off the newer brackets ie cable, handle, cable springs etc. to our older mounts.
You have to bend both sides as the seat is in the center of the truck.
The only part that is not off the new seat in the actual mount. The tracks, springs, cable, etc...is all from the new seat.
Dan
FORD Girl
Tim P.
Post by Tim P. »
im confused by your last post I wanted to know if the seat adjustment on the new seat stays with the new seat even tho im using the old tracks ,,, I havent taken a good look at this yet on the new one so I was pre asking this before I investigate it further for install. I would like to keep the new adjustment lever and cable with the new donor in lue of using the old truck type adjustment that comes out towards the drivers door.
MadMaxetc
Post by MadMaxetc »
Tim P. wrote:...I wanted to know if the seat adjustment on the new seat stays with the new seat even tho im using the old tracks
There are 3 main parts to the ford betch seats.
The bench (Frame, Springs, Cover.)
The tracks (Allow forward and back adjustment)
and the Mounts (these are riveted onto the tracks <PICTURE>)
Tim P. wrote:...I would like to keep the new adjustment lever and cable with the new donor in lue of using the old truck type adjustment that comes out towards the drivers door.
So did I. That is why I drilled out the rivets and bolted the Newer tracks onto the Old mounts.
<PICTURE>
Here is the page on my site <HERE>
I like the newer tracks better, they have a better engagement design that feals a lot tighter than the old style.
Dan
FORD Girl
1971ford
Post by 1971ford »
when i got my 69, i found out that chevy bench seats will weld right on to the ford brackets :D
(dont worry i have allready gotten a ford seat for replacement and taken the chevy seat out)
-Ryan
basketcase0302
Post by basketcase0302 »
Ryan,
That's good news, (cause your truck would definitely pay you back for the chebby parts). :D
Seat upgrade will be in my future as well.
Basketcase
1971ford
Post by 1971ford »
thats not it though. :(
there is a chevy bumper that doesnt fit(has maded a dent on each side of box) and is wavy welded on and a hitch under it welded to the bumper and frame. im going to have the PO cut all that off.
-Ryan
