bed cover
- customcrewcab
bed cover
started on the frame work for my bed cover. it should sit flush with the top of the bed rails
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
re: bed cover
nice
what type of material is the cover going to be made of?
71 F100 XLT Ranger
04 F150 FX4
06 F150 XL
- customcrewcab
re: bed cover
some sheet metal. not sure what gauge yet. trying to keep light but i don't want it too thin where its easy to dent. thinking i will make it raise in the all 4 corners about 1.5 straight up.
- dablack00
re: bed cover
I always wanted a bed cover that was flush w/ the top of my bed too. I was thinking something along the lines of what you are doing, but on a slide. Sort of like a drawer. That way as long as the tail gate is up, it can't slide out, but then lower the tail gate and you can slide it all out a couple of feet to put something up against the cab.
I'm looking forward to seeing your done so I can see how it looks.
- marz68
- customcrewcab
re: bed cover
nah its 5/8''s
