Fuse panel on kick panel?
- 71 LONG BED
Why would there be another fuse panel over here? I should have looked to see if this is another one or the only one. It is in a '68 F600.
John Member #1549
- dbarker
my 68 is factory & there is no such fuse box. Mine is in the normal location. This one was added by someone else.
Drew
See My Gallery -http://www.fordification.com/galleries/ ... ?album=913
My Website: http://www.drewbarker.net
- kaptnkaos
re: Fuse panel on kick panel?
Dbarker...
That fuze panel is on a '68 f-600 not the same as your f-100 at all.
KaptnKA
S
KaptnKA
- 71 LONG BED
John Member #1549
i can not be sure but i stripped a f500 lsat year and i think but i am not sure that the fuse box was also on that truck like that. the truck is gone now so i cant confirm, it.
how do the wiring connections from and to the box look are they factory connectors ? aftermarket connectors? or crimp on newbie style connectors? that will probably tell you more about where the box and wiring may have came from.
- kaptnkaos
The fuze panel on my '68 B-500 bus is also on the "passenger" side...
It only had 5 fuzes... I thought that wierd.
I had to install a new fuze panel 'cause a couple of the slots on the original were no good.
I upgraded to a blade style box that I got at NAPA.
double click to enlarge pic
I have added a couple more circuits since then.
It would be really easy to add another box if I need more fused circuits
KaptnKA
S
KaptnKA
