LH Rear blinker not working
My blinker is not working on the back of the truck (driver's side). It's not the bulb. I checked that. The running lights work and the blinker works on the front of the truck.
re: LH Rear blinker not working
Could be the turn signal switch...
Look at this diagram http://www.fordification.com/images/sch ... _quick.jpg it will be the same for your 71... Take a test light to the connector for the wires coming out of the collum and test the Green wire. This is the one for the left turn / brake light, the Green with White strip is for the front left turn light...
If you don't have any power there on this Green wire then your turn signal switch is bad...
What you have is a classic symptom of a broken wire on the turn signal switch. I'd pop off the steering wheel to have a look.
does this have the trailer wire harness in tact check that as well some of the connections at where its tied in,, it might be corroded for the signal wire even if it seems taped well they still need attention every now and again.
- rjewkes
i had power coming out that very wire from the column but through the harness on the other side of the firewall it didn't get the power so i bypassed it just south of the plug.
also iunless 72 is different from the other years the lh turn signal/ brake is yell with black stripe.
also if the brake lite on that side works then it is the bucket/socket not getting enough or any ground to light the turn but then it would burn solid though
I'm going to tackle this job this weekend along with replacing some seals, my radiator hose, maybe install my Pioneer, work on the brakes......Or just sit around and watch the Alabama game on Saturday
rjewkes wrote: also unless 72 is different from the other years the lh turn signal/ brake is yell with black stripe.
Glad you caught that rjewkes
- rjewkes
No problem.
Hope it is a quick fix.
