#11 - Mar. 17, 2007
How's your Ford truck parts knowledge?
FORDification
Site & Forum Admin
Site & Forum Admin
#11 - Mar. 17, 2007
Post by FORDification »
This one might stump a bunch of you, depending on how far down you've dismantled your trucks: :evil:
[img]http://www.fordification.com/board/triv ... -07[2].jpg[/img]
I'd estimate that 90% (or more) of all '67-'72 trucks have two of these. This oval-shaped object is about an inch wide, maybe a tiny bit more. What is it?
the trucks i have dismantleted were with sawzalls and torches in places were they wouldn't come apart. so i am unsure on this. but i would be safe in saying that its a washer.
gmcjimmy88
re: #11 - Mar. 17, 2007
Post by gmcjimmy88 »
Looks like a camber washer, What years and models I would not be able to answer if I was correct.
averagef250
Post by averagef250 »
I think I've been lucky enough to only own trucks in the 10% that didn't get them. That's a stumper.
ezernut9mm
Post by ezernut9mm »
some kind of body shim???
rjewkes
Post by rjewkes »
Is it for the bumper up front to shim it if the frame is bent?
AustinTom
Post by AustinTom »
Is it a shim used to position the components of the drum brakes on 2wd truck?
69 F-100 lwb 240 Np435
95 F-150 lwb 4x4
http://s110.photobucket.com/albums/n85/ ... type=local
FORDification
Site & Forum Admin
Site & Forum Admin
Nobody's even close yet. :evil: OK, I'll give you a little hint. The above-pictured item isn't a shim, it's a specialty washer...and there's one on each side of the truck.
...and if you were to slice your truck in half top-to-bottom, these will be located in the top half. :pop:
rjewkes
Post by rjewkes »
ahhhhhhhhhhhhhhh! Bach! The washeer behind the striker for the door latches.
the only thing i can think of and i think i'm wrong. is that it might have been a washer that goes on the choke cable behind the dash before the nut tightens down the choke cable. but none of my trucks have that washer so i am wrong.
averagef250
On bumpside wing windows there's a threaded stud that sticks out the bottom. It has a nut, spring and several metal and plastic washers on it. The specialized washer in the picture looks like the uppermost washer on that lower wing window stud.
ToughOldFord
Post by ToughOldFord »
Part of the seat belt mount?
FORDification
Site & Forum Admin
Site & Forum Admin
averagef250 wrote:On bumpside wing windows there's a threaded stud that sticks out the bottom. It has a nut, spring and several metal and plastic washers on it. The specialized washer in the picture looks like the uppermost washer on that lower wing window stud.
...and Dustin got it!! :clap: Yep, that's the upper washer for the lower vent window assembly mount. The lower washer is round, the upper washer (yellow arrow) is oval-shaped and is what is featured in this Truck Trivia segment. :D
68F250
Post by 68F250 »
Ah-ha! The washer looks a lot bigger in the pic, could you put a pencil or coin by it next time? :D
Barry
gmcjimmy88
Very good. At least I was the first guess LOL. Nope I was second oh well.
