ok i just went out turned the key and turned on the blower to see if it was ok enough to start driving the truck to school and i get a high spinng metal scraping sound.... that never goes away... whats the cause of it or can i fix it or should i just get a new one?
Nick
blower motor in the 67
it rubbing on something. it could be something in there that is making it do that or the thing need the squirrel cage adjusted further away from what its hitting. if it is unable to be adjusted any further then the bushing must be worn out and the motor will not hold the cage in the right place so it will scrape something. if the bushing are going to where you can't fix it you possibly need a new one.
- ICEMAN6166
re: blower motor in the 67
could be the bearing in the motor too. you need to remove it and take a look.
http://fordtruk.com/forums/album.php?ca ... user_id=26
you can ford a river or stream and get to the other side, if you dodge it you will not, and if you drive a chevy to the levee it will run dry and the music will die.
take it out of the heater box . and see if there is anything in there. also look for any shiny spots where it has been grinding against something. to make the adjustment there is a allen head screw in the center of the cage that holds the cage to the motor shaft. it won't need much adjustment so don't move it very far when you do.
- jor
In my experience, it's always been the bearing. Oftentimes, the noise will go away if you keep running it. If not, pick up another motor.
jor
jor
