Grounds
- $500F100
Grounds
I am still working on getting my charging system up and working properly. I am in the process of checking all the grounds. Where does the chassis typically ground to the frame? What gauge wire should be used for engine to chassis and chassis to frame grounds.
- MadMaxetc
re: Grounds
I ground the firewall to the engine and the engine to the frame. I also put a wire from the bottom of the firewall to the frame.
Dan
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
FORD Girl
Photobucket Pictures
FORD Girl
- rjewkes
Our ford ground battery negative to some where on the engine just under and behind the Alternator area. Then engine To Firewall.
I guess it don't hurt to ground to the frame from the firewall.
- cathynkeith
re: Grounds
I have 2' braided strap from motor to frame and 4 other 1/2" straps around the truck, body to battery, cab to frame tail lights to body (flairside) and bed to frame.
Can not ground it too much!
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
1969 f100 flareside
- jor
re: Grounds
Here's a photo of my braided connection from the engine to the cab and another of the negative battery cable to the engine (as rj said, right under the alternator). I think you can get the braided strap at Autozone or Checkers.
jor
jor
- ICEMAN6166
re: Grounds
battery cables should be a minimum of AWG 4 but i always use AWG 2 or larger.the neg cable must be at least the same as the pos. but can be larger ,never should be smaller.same goes for the cable going from sol. to starter, can be slightly smaller than the one on the batt. but not larger.
if you have a AWG 2 on your battery you can use a 4 to the starter but not the reverse.
the other wire grounds are typically 10 AWG.
re: Grounds
2 ga from the battery to the block. Ground strap...(the 1" wide kind , ) at the rear of the motor, bellhousing bolt to frame. Small ground strap (1/4 style) from the forewall to the engine (valve cover bolts) All connections clean, no rust,junk,funk, paint...etc. Star washers at all points.
just my .02..but it works
- ratfink
re: Grounds
The same amount of current (amps) flows thru the ground as thru the positive one. That is why you should have the same size ground cable as the positive one at the battery.
Ratfink
Ratfink
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- MadMaxetc
re: Grounds
I would not go to the valve cover. I would go to an intake bolt. I plan to put a longer stud on my 460 in the back so I can put another nut on it.
Dan
FORD Girl
FORD Girl
