no juce.
no juce.
well hello all, it has been a long time since I worked on the truck but I am back. and today I thought that I would check the electrical wiring...so I looked everything over and put a brand new battery on it and..............nothing....not even a spark................totaly dead. so back to square one..tomorrow I am going to chase down all the grounds and look for anything that I missed..............man I hate wiring!!!!
- 71 LONG BED
Re: no juce.
You and me both!!widegauge wrote:man I hate wiring!!!!
John Member #1549
- splavin90
re: no juce.
so is your starter turning over your engine? or not?
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
re: no juce.
I got nothing yet. but I havent looked at it again.
- 19674x4
i did this, make sure your battery cables are on the right posts. also check your relay, can you jump the sylonoid, do you have spark at the plugs.
My Photo Album
re: no juce.
no I mean I have nothing, no lights, no starter, no horn, no nothing. as if I didnt even have a battery on it......but like I sad I need to look it over again, and no matter how stupid the fix is I will tattle on myself.
- 19674x4
is the battery charged. put it on a trickle charger and let it charge over night. then try it. make sure you wires are on the correct posts
My Photo Album
re: no juce.
Where in FL. Pretty humid there. Make sure all your connections are
clean and tight. If you put a light coat of grease on them it will keep
the air/moisture out a little better. Good luck, KeithP
- 71 LONG BED
re: no juce.
John Member #1549
re: no juce.
check the neutral safety switch. It won't do anything till that is positioned right. I used to have to hold it in place while I started it. no one could use it but me....
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
